Configure VLACP Globally
Use VLACP as an extension to LACP for end-to-end failure detection. Enable or disable VLACP globally to reset the port level configuration. The default is disabled.
Important
Important
Changes you make at the global level override and reset all port level settings.
    enable
    configure terminal
  2. Enable VLACP globally:
    vlacp enable
  3. Disable VLACP globally:
    no vlacp enable
Switch:1(config)# vlacp enable
